di 2510 don`t boot up
  • boanda
    • Feb 2011
    • 79
    [Error Code] di 2510 don`t boot up
    I got secondhand di 2510 and on every start up I get message on screen "DON`T BOOT UP"
    also, i can't make it to scan, only can print and copy
    In service book writes that the machine has SU2 and FAX unit?, but PS drivers want work too
  • xeroprint
    • Nov 2008
    • 20
    REmove scan and print card. Check it. Rewrite firmware.
    • Darren King
      copiertech
      • 652
      The only time I have seen "don't boot up" on one of these machines is when the CF card is not in.
      Hope this helps
      Darren
      • xeroprint
        • Nov 2008
        • 20
        You must insert CF card.
        • aesthetics1
          • May 2010
          • 148
          This machine won't print with a PostScript driver unless it has the PostScript Interpreter option. Try the PCL driver and you will probably find that it works fine.
          Don't Boot Up! messages can be attributed to dead/dying SU-2 scan chips, dead/dying PCL/MP chips, or chips put in the wrong slot (ie reversed,) as well as problems with the device's firmware.
          • boanda
            • Feb 2011
            • 79
            CF card is in, I must shut it down and up,every morning,few times then the machine works fine all day, coping and printing with PCL
            When I try to print with PS, I saw that the document has been spooled but want to print, and not showing any error.
            Ill try to find some old SU2/3 to replace with existing one and flush the machine to see what happens.
            TY all for big help, i suspect on su2 but,honestly, practically this is the first time that I have this kind of problem and I really appreciate
            yours help.
            Ill let u know what solved the problem
            • aleksander
              • 378
              check the firmware or re-format your CF card.
              • boanda
                • Feb 2011
                • 79
                CF card replaced and new firmware added and all working fine!
                TY all for help!
